Find drawing referenced WtPart on POST_CHECKIN event
Hello everyone,
 I have developed this code that find all the WtPart refrenced by a drawing (.drw).
It's works fine on a stand alone Java application , but when I try to do the same on a POST_CHECKIN Listener the code is unable to find the referenced objects.
Is it matter of the calculation link ?
Thank you !
public static WTPart wtpRetrieveDrawingAssociatedWtPart(EPMDocument epm) throws Exception {
  WTPart wtPart = null;
  CADAssociatedParts relationship = new CADAssociatedParts();
   relationship.setTypes(CADAssociatedParts.Type.CALCULATED_BUILD);
  List<Object[]> epmDocs = EPMNavigateHelper.navigate(epm, relationship, CollectItem.SEED_ID, CollectItem.OTHERSIDE).getRawResults();
  if(epmDocs != null) {
   for(Object[] objects : epmDocs) {
    for(Object o : objects) {
     if(o instanceof WTPart) {
      WTPart tempPart = (WTPart) o;
      System.out.println("StandardListenService: " + epm.getName() + " WtPart referenced by" + tempPart.getName() + " " + tempPart.getNumber() );
      if(tempPart.isLatestIteration()) {
       if (tempPart.getName().toLowerCase().contains(".asm")) {
       wtPart = tempPart;
       break;
  return wtPart;
ShirishMorkhade
Hi @gfontana,
A quick suggestion, can you check and validate for POST_STORE event?
Shirish
ShirishMorkhade
Hi @gfontana,
Shirish
gfontana1-VisitorAuthor
Hi ShirishMorkhade,
I'm sorry for the delay in answer to your suggestion.
Anyway the POST_STORE work fine, so now i'm able to reload all calculated links
Thank you very much
Giorgio
Hi Giorgio,
I am facing the same issue.
I am trying to get the Reference EPMDocuments while checkin the Drawing using the POST_STORE  event.
Can I know which API you are using?
Hemanth Kumar
