Form Based Authentication with Active Directory
Dear Community,
we are planning to change the Windchill Authentication to Form Based Authentication.
Windchill is connected to the Active Directory of the customer as well.
How does the configuration look like in the tomcat settings? Does anybody have an example?
We have entered in the server.xml the Realm entries as below (but we are not sure about how the Active Directory entry look like):
In the web.xml file:
Thanks in advance.
xolomonAnswer
thanks for your response. This was more specific question which I couldn't find any solution in the PTC support page.
We have managed to configure based on the article below. Each company has different LDAP configuration and it has to adjusted accordingly.
https://tomcat.apache.org/tomcat-7.0-doc/realm-howto.html#JNDIRealm
Cheers.
Hi
There are many search results for this in the link below, I hope one will help you.
cheers -- Rick
https://support.ptc.com/search/Pages/results.aspx#k=form%20based%20authentication
xolomon14-AlexandriteAuthorAnswer
Cheers.
