Dobi
Get WTPart attribute for associated EPM model OR drawing
Version: Windchill 13.0
Use Case: Working on getting specific WTPart attributes overlaid on published drawing PDFs.
Description:
I thought this would be simple enough but I ended up struggling the last two days in trying to achieve the following:
  • Code collects and makes available an EPMDocument ID. ✔️
    • EPMDocument could be either a drawing or a model and it will have an associated WTPart.
If this is a drawing:
EPMStructureHelper.service.navigateReferences(etc etc)
instead... from here I can't resolve either the EPMReferenceLink IDs or the EPMDocumentMasters (depending on the boolean settings) to get the related model.
It's not clear to me where to go to get the "rolename" values or "buildrule" integer values to be able to go directly from the drawing to the WTPart. That would be ideal.
There's CS351622 that goes over how to fetch an owner linked WTPart. Assuming here that if I change "OWNER" to "IMAGE" or "CALCULATED" (?) this may give me what I want?
I just feel like I'm missing some pretty important pages from some customization guide somewhere...
joe_morton
I think you'll have to split the code into two cases:
  • If the EPMDocument you start with is a model, it should be pretty straightforward to get the WTPart.
  • If the EPMDocument you start with is a drawing (with calculated link to WTPart), you'll have to navigate from drawing -> model master -> version of model you want (latest?) -> WTPart
From drawings, Windchill stores at least 3 types of links to other CAD files:
  • Drawing Reference - the model added directly to the drawing. This is the one you want, but there can be multiple of these!
  • Default - additional references (child components in an assembly, for example)
  • Drawing Format Reference
Not a full solution, but hope that helps point you in the right direction
Something you may want to consider as a shortcut would be if you have any numbering conventions for your models / drawings / WTParts. We, for instance, basically match the number on all three, so as long as things are numbered correctly (BIG IF), I could use the number from the first EPMDocument, then run a query to get the WTPart with the number that corresponds.
18-Opal
What type of link are you using to link the WTPart and CAD drawing?
Image and Calculated?
Not Content?
Dobi
Dobi17-PeridotAuthor
Generally, the drawing will only ever be calculated. The model could be either image or owner but not content.
18-Opal
I meant is the drawing a Content link not the model. Regardless as long as we know it’s Calculated link that all we need to know.
Do you understand what a calculated link is?
Meaning how it is calculated?
From your description, it seems you are looking to navigate the DescribedBy from a WTPart to an EPMDocument Drawing?
You might want to chceck:
- https://www.ptc.com/en/support/article/CS131357
- https://www.ptc.com/en/support/article/CS240504
- https://support.ptc.com/help/windchill/r13.1.0.0/en/#page/Windchill_Help_Center/ManagingCADandPartRelationships/MCPR_AssociationOview.html
This code snippet may help:
wt.fc.collections.WTCollection parts = new wt.fc.collections.WTArrayList();
parts.add(part);
wt.fc.collections.WTKeyedMap associatedCADDocumentMap = ((wt.part.StandardPartDocService)wt.part.PartDocHelper.service).getAssociatedCADDocuments(parts);
Dobi
@MalteSiefkes
I'm looking to navigate the opposite way: from an EPMDocument (either drawing or model) to a WTPart.
So likely this may give me what I want:
com.ptc.windchill.collector.api.cad
getAssociatedParts(EPMDocument seed)
joe_morton
