Getting global attributes of WTDocument by OData
Hello everyone!
Please tell me how can I get the values of global attributes in a WTDocument using OData?
Version of Windchill REST Services - 1.4.
Now I can only get attributes such as number and name.
Thanks in advance.
Regards!
hlafkirAnswer
Hi @VladiSlav,
Please refer to this helpful article :
@VladiSlav
If you have a simple IBA, you just have to add in Parts.json the following :
"name":"IBA",
"internalName":"IBA",
"type":"String"
  • Here an illustration with a custom enumtype (adding an IBA linked to a  Global Enumeration).
Create an entry in Parts.json, specifying a new attribute. As it is an enumeration, I will add the following :
                               "name": "EnumString",
"internalName": "EnumString",
"type": "PTC.EnumType"
In Parts.json, findable in codebase\rest\ptc\domain\ProdMgmt\v2\entity\Parts.json
Then it will look like this :
 "name":"Part",
 "collectionName":"Parts",
 "type":"wcType",
 "wcType":"wt.part.WTPart",
 "description":"Parts",
 "operations":"CREATE,UPDATE,DELETE",
 "attributes":[
 "name":"Name",
 "internalName":"name",
 "type":"String",
 "required":true
 "name":"Number",
 "internalName":"number",
 "type":"String"
 "name":"EndItem",
 "internalName":"endItem",
 "type":"Boolean",
 "driver":true
 "name":"TypeIcon",
 "internalName":"type_icon",
 "type":"PTC.Icon",
 "readOnly":true
 "name":"Identity",
 "internalName":"identity",
 "type":"String",
 "readOnly":true
 "name":"GeneralStatus",
 "internalName":"statusFamily_General",
 "type":"PTC.Icon",
 "readOnly":true
 "name":"ShareStatus",
 "internalName":"statusFamily_Share",
 "type":"PTC.Icon",
 "readOnly":true
 "name":"ChangeStatus",
 "internalName":"statusFamily_Change",
 "type":"PTC.Icon",
 "readOnly":true
 "name":"Supersedes",
 "internalName":"statusFamily_Supersede",
 "type":"PTC.Icon",
 "readOnly":true
 "name":"AssemblyMode",
 "internalName":"partType",
 "type":"PTC.EnumType",
 "required":true
 "name":"DefaultUnit",
 "internalName":"defaultUnit",
 "required":true
 "name":"DefaultTraceCode",
 "internalName":"defaultTraceCode",
 "required":true
 "name":"Source",
 "internalName":"source",
 "required":true
 "name":"ConfigurableModule",
 "internalName":"genericType",
 "name":"GatheringPart",
 "internalName":"hidePartInStructure",
 "type":"Boolean",
 "required":true
 "name":"PhantomManufacturingPart",
 "internalName":"phantom",
 "type":"Boolean",
 "required":true
 "name":"BOMType",
 "internalName":"variation1",
 "name":"AlternateNumber",
 "internalName":"variation2",
 "inherits":[
 "name": "versioned"
 "name": "contextManaged"
 "name": "lifecycleManaged"
 "name": "viewManageable"
 "name": "workable"
 "name": "representable"
 "name": "organizationOwned"
 "name": "foldered"
 "navigations":[
 "name":"Uses",
 "target":"PartUses",
 "type":"PartUse",
 "isCollection":true,
 "containsTarget":true
 "name":"UsedBy",
 "target":"Parts",
 "type":"Part",
 "isCollection":true
 "name":"DescribedBy",
 "target":"PartDescribeLinks",
 "type":"PartDescribeLink",
 "name":"References",
 "target":"PartReferenceLinks",
 "type":"PartReferenceLink",
 "functions":[],
 "actions":[
 "name":"GetBOM",
 "description":"Get Bill Of Materials",
 "parameters": [{
 "name":"part",
 "type":"Part",
 "isNullable":false,
 "isCollection":false
 "name":"navigationCriteriaId",
 "type":"String",
 "isNullable":true,
 "returnType": {
 "type":"BOM",
Without restarting Windchill :
GET http://pdm10.de/Windchill/servlet/odata/ProdMgmt/Parts('VR:wt.part.WTPart:2874036') In Postman
Give this output :
    "@odata.context": "http://pdm10.de/Windchill/servlet/odata/v2/ProdMgmt/$metadata#Parts",
    "@odata.type": "#PTC.ProdMgmt.AsArticle",
    "ID": "OR:wt.part.WTPart:2874037",
    "Name": "MyPar",
    "Number": "0000071301",
    "EndItem": false,
    "TypeIcon": {
        "Path": "http://pdm10.de/Windchill/netmarkets/images/config_part.gif",
        "Tooltip": "Configurable Module"
    "Identity": "0000071301, MyPar, Demo Organization, A (Design)",
    "GeneralStatus": {
        "Path": "http://pdm10.de/Windchill/com/ptc/core/htmlcomp/images/checkedout_byyou9x9.gif",
        "Tooltip": "Working copy, checked-out to you"
    "ShareStatus": null,
    "ChangeStatus": null,
    "Supersedes": null,
    "AssemblyMode": {
        "Value": "separable",
        "Display": "Separable"
    "DefaultUnit": {
        "Value": "ea",
        "Display": "each"
    "DefaultTraceCode": {
        "Value": "0",
        "Display": "Untraced"
    "Source": {
        "Value": "make",
        "Display": "Make"
    "ConfigurableModule": {
        "Value": "dynamic",
        "Display": "Yes"
    "GatheringPart": false,
    "PhantomManufacturingPart": false,
    "BOMType": null,
    "AlternateNumber": null,
    "EnumString": {
        "Value": "SteelSheets",
        "Display": "Steel Sheets"
    "View": "Design",
    "CheckoutState": "Working copy, checked-out to you",
    "CheckOutStatus": "cat-working-copy",
    "Comments": null,
    "State": {
        "Value": "INWORK",
        "Display": "In Work"
if it does not work please expose here how you are driving this use case.
best regards
Hicham
hlafkir5-Regular MemberAnswer
Hi @VladiSlav,
@VladiSlav
"name":"IBA",
"type":"String"
 "name":"Part",
 "type":"wcType",
 "attributes":[
 "name":"Name",
 "type":"String",
 "required":true
 "name":"Number",
 "type":"String"
 "name":"EndItem",
 "type":"Boolean",
 "driver":true
 "name":"TypeIcon",
 "type":"PTC.Icon",
 "readOnly":true
 "name":"Identity",
 "type":"String",
 "readOnly":true
 "type":"PTC.Icon",
 "readOnly":true
 "type":"PTC.Icon",
 "readOnly":true
 "type":"PTC.Icon",
 "readOnly":true
 "type":"PTC.Icon",
 "readOnly":true
 "required":true
 "required":true
 "required":true
 "name":"Source",
 "required":true
 "type":"Boolean",
 "required":true
 "type":"Boolean",
 "required":true
 "name":"BOMType",
 "inherits":[
 "name": "versioned"
 "name": "workable"
 "name": "foldered"
 "navigations":[
 "name":"Uses",
 "type":"PartUse",
 "name":"UsedBy",
 "target":"Parts",
 "type":"Part",
 "isCollection":true
 "functions":[],
 "actions":[
 "name":"GetBOM",
 "parameters": [{
 "name":"part",
 "type":"Part",
 "isNullable":false,
 "type":"String",
 "isNullable":true,
 "returnType": {
 "type":"BOM",
Give this output :
    "Name": "MyPar",
    "EndItem": false,
    "TypeIcon": {
    "GeneralStatus": {
    "Supersedes": null,
    "AssemblyMode": {
    "DefaultUnit": {
        "Value": "ea",
        "Display": "each"
        "Value": "0",
    "Source": {
        "Value": "make",
        "Display": "Make"
        "Value": "dynamic",
        "Display": "Yes"
    "BOMType": null,
    "EnumString": {
    "View": "Design",
    "Comments": null,
    "State": {
        "Value": "INWORK",
best regards
Hicham
VladiSlav17-PeridotAuthor
Thank you very much for your reply!
I added these lines to Documents.json:
 "name":"IBA",
 "type":"String"
And I get these answers to the request:
<d:EnumString m:null="true"/>
<d:IBA m:null="true"/>
here is the main part of my request:
Windchill/servlet/odata/v1/DocMgmt/Documents
What am I doing wrong?
Thanks in advance!
But what are the internal names of your global attributes ? (in type and attribute manager)
Hicham
