Getting Usage link attrubutes API
Is there an API  to retrieve the uses attributes in the part structure for WTPart?
Attributes such as Line Number, Quantity, Unit, Trace Code, Reference Designator, Find Number.
HelesicPetr
Hi @WM_9965332
You can use something like this:
QueryResult qResult = WTPartHelper.service.getUsesWTParts(primWtp, new LatestConfigSpec());
while
(qResult.hasMoreElements())
Object[] obj = (Object[]) qResult.nextElement();
WTPartUsageLink link = (WTPartUsageLink) obj[0];
WTPart subWTP = (WTPart) obj[1];
long lineNumber = link.getLineNumber().getValue();
double amount = link.getQuantity().getAmount();
String unit =
link.getQuantity().getUnit().getStringValue();
String traceCode = link.getTraceCode().getStringValue();
PetrH
HelesicPetr
Hi @WM_9965332
while
String unit =
PetrH
Thank you! Is there a way of getting the enumerated display value?
For instance, for unit I'm getting wt.part.QuantityUnit.ea instead of ea (each). And for tracecode I'm getting wt.configuration.TraceCode.0 instead of Untraced
HelesicPetr
Hi @WM_9965332
If you use IDE to write code, you should find the methods you need.
PetrH
