Getting value of IBA by Java
Hello everyone!
I tried to get the values of global attributes through RMI, I could not do it.
Tell me, please, how can I do it?
Are there other ways in java to do it?
For example, through the odataWeb.jar library classes?
Thanks in advance!
Respectfully!
Hi
Please check this sample where you will be able to update an IBA via RMI invocation. Note that you not have to check out the document if you want to only read the IBA value. :
public class updateIBA implements RemoteAccess {
	public static void main(String[] args)
	 // Retrieve a MethodServer remote reference
	 // from the ServerManager
	 RemoteMethodServer rms = RemoteMethodServer.getDefault();
	 // Authenticate using the default
	 // HTTPLogin Authenticator
	 rms.setUserName("wcadmin");
	 rms.setPassword("ts");
	 try
	 rms.invoke("update",
	 "ext.training.updateIBA", null, null, null);
	 System.out.println("Should have worked, check the MS log");
	 catch (Exception e)
	 e.printStackTrace();
 public static void update()
 try
 ObjectIdentifier oid = ObjectIdentifier.newObjectIdentifier("wt.doc.WTDocument:2956425");
 WTDocument object = (WTDocument) PersistenceHelper.manager.refresh(oid);
 Folder folder = WorkInProgressHelper.service.getCheckoutFolder();
 CheckoutLink cout = WorkInProgressHelper.service.checkout(object, folder, "checkedout");
 WTDocument manuf_copy = (WTDocument) cout.getWorkingCopy();
 PersistableAdapter obj = new PersistableAdapter(manuf_copy, null, SessionHelper.getLocale(), new UpdateOperationIdentifier());
 obj.load("intt");
 obj.set("intt", "158");
 object = (WTDocument) obj.apply();
 PersistenceHelper.manager.modify(object);
 WorkInProgressHelper.service.checkin(object, null);
 catch (Exception e)
VladiSlav17-PeridotAuthor
Thank you very much for your reply!
After starting, I have the following error:
wt.util.WTRemoteException: Unable to invoke remote method; nested exception is:
	java.lang.NoSuchMethodException: com.com.acme.Test.update()
What am I doing wrong?
