3-Newcomer
Has anyone been able to create a replication package using infoengine
Version: Windchill 12.0
Use Case: I am trying to automate creation of replication packages to synchronise two disconnected windchill instances with 500+ potential contexts to be synchronised. The code below is for a test with all the values hard coded. Windchill 12.0.2.11
Description:
This is the code but I either get a create or save error and an java.lang.instantiation exception. I have read in the API that the newReplicationPackage constructor should be used but not sure how to incorporate that,
<%@page language="java" access="internal|http"%>
%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%
https://xxxx/Windchill/servlet/IE/tasks/com/thalesuk/createPackage
Input file format: Current Name, New Name
<%@ page import="java.util.*"%>
<%@ page import="wt.adapter.*"%>
<%@ page import="wt.part.*"%>
<%@ page import="wt.fc.*"%>
<%@ page import="wt.pdmlink.*"%>
<%@ page import="wt.vc.config.*"%>
<%@ page import="wt.vc.views.*"%>
<%@ page import="wt.type.*"%>
<%@ page import="java.io.*"%>
<%@ page import="wt.fc.collections.WTKeyedMap"%>
<%@ page import="wt.fc.collections.WTKeyedHashMap"%>
<%@ page import="wt.util.WTException"%>
<%@ page import="com.ptc.windchill.wp.rep.*"%>
// PARAMS:
IeService ie = getService();
Element message = new Element("message");
Group rGroup = new Group("returningGroup");
 <ie:webject name="Get-Properties" type="MGT">
 <ie:param name="ATTRIBUTE" data="wt.federation.ie.VMName"/>
 <ie:param name="GROUP_OUT" data="properties"/>
 </ie:webject>
 <ie:webject name="Query-Objects" type="OBJ">
 <ie:param name="INSTANCE" data="$(properties[0]wt.federation.ie.VMName[0])" />
 <ie:param name="TYPE" data="wt.inf.container.WTContainer" />
 <ie:param name="ATTRIBUTE" data="name" />
 <ie:param name="WHERE" data="name='xxx'" />
 <ie:param name="GROUP_OUT" data="org" />
 </ie:webject>
try {
 <ie:webject name="Create-Objects" type="ACT">
 <ie:param name="INSTANCE" data="${properties[0]wt.federation.ie.VMName[0]}"/>
 <ie:param name="CONTAINER_REF" data="OR:wt.pdmlink.PDMLinkProduct:380344479"/>
 <ie:param name="TYPE" data="com.ptc.windchill.wp.rep.ReplicationPackage"/>
 <ie:param name="METHOD" data="newReplicationPackage"/>
 <ie:param name="FIELD" data="name=TEST_Webject"/>
 <ie:param name="FIELD" data="orgid=$(org[]obid[])"/>
 <ie:param name="FIELD" data="domainRef=$(org[]obid[])"/>
 <ie:param name="FIELD" data="packageDomain=OR:wt.pdmlink.PDMLinkProduct:380344479)"/>
 <ie:param name="GROUP_OUT" data="pack"/>
 </ie:webject>
} catch(Exception e) {
 e.printStackTrace();
 message.addAtt(new Att("failed", e.getMessage() ) );
rGroup.addElement(message);
addGroup(rGroup);
<ie:webject name="Return-Groups" type="GRP">
 <ie:param name="group_in" data="returningGroup"/>
</ie:webject>
Any pointers to a solution would be very helpful
Catalina
Community Manager
Hi @IT_10321741
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
