help,modify Project updateAttribute code is correct?
package ext.training;
import ext.generic.util.IBAUtility;
import wt.fc.PersistenceHelper;
import wt.fc.QueryResult;
import wt.projmgmt.admin.Project2;
import wt.query.QueryException;
import wt.query.QuerySpec;
public class ModifyProjectAtt {
  public static void modifyPrtAtt() throws Exception{
  try {
  QuerySpec qs = new QuerySpec(Project2.class);
  QueryResult rs = PersistenceHelper.manager.find(qs);
  while (rs.hasMoreElements()) {
  Project2 proj= (Project2) rs.nextElement();
  IBAUtility iba = new IBAUtility(proj);
  String prdType = iba.getIBAValue("PRODUCTDEVELOPTYPE");//產品種類
  if(prdType == null  || prdType.trim().equals("")){}
  else{
  if(prdType.indexOf("類")>-1){
  }else{
  String corType = prdType+"類";
  iba.setIBAValue("PRODUCTDEVELOPTYPE", corType);//設定新的Type名稱
  iba.updateAttributeContainer(proj);//更新project
  iba.updateIBAHolder(proj);
  } catch (QueryException e) {
  // TODO Auto-generated catch block
  e.printStackTrace();
Can you say version of Windchill?
I think, you can try PersistableAdapter (or depricated LWCNormalizedObject )
PersistableAdapter PObj = new PersistableAdapter(proj,null,null,null);
PObj.load("PRODUCTDEVELOPTYPE");
PObj.set("PRODUCTDEVELOPTYPE", corType);
PObj.apply();
Example usage from API doc (%Windchill%\Windchill\codebase\wt\clients\library\api\com\ptc\core\lwc\server\PersistableAdapter.html):
CREATE
Locale locale = SessionHelper.getLocale(); PersistableAdapter obj = new PersistableAdapter("com.acme.AcmePart",locale,new CreateOperationIdentifier());
obj.load("name","number");
obj.set("name","my name");
obj.set("number","12345");
obj.persist();
RETRIEVE
PersistableAdapter obj = new PersistableAdapter(my_persistable,null,locale,null);
Object nameValue = obj.get("name");
Object numberValue = obj.get("number");
UPDATE
PersistableAdapter obj = new PersistableAdapter(my_persistable,null,locale,new UpdateOperationIdentifier());
obj.load("attributeA","attribtueB");
obj.set("attributeA",Boolean.TRUE);
obj.set("attribtueB","PURPLE");
obj.apply();
PersistenceHelper.manager.modify(my_persistable);
Best regards
kdungyi1-VisitorAuthor
version is windchill 10.2 ,  runtime by workflow
Ok, use PersistableAdapter
