Feb 5, 2024 11:12 AM UTC
Hide/Remove customized action from Project Link for WTPart object
Hello PTC Community team/members,
I have created one customized action for WTPart but whenever I share any WT Part to Project Link that same action also visible into Project Link. Can anyone know how I can hide/remove that customized action for the team/role. Attached picture for the reference(yellow highlighted action, I want to hide).
HelesicPetr
Feb 5, 2024 11:27 AM UTC
Hi @Vaibhav_Thakare
It is a link to the Windchill help center 13.0.1.0
My access has been also denied to  13.0.1.0 so try  13.0.0.0
Implementing Validation Filters
or go to help https://www.ptc.com/en/support/help/Windchill and search for the Validation filter
PetrH
HelesicPetr
Feb 5, 2024 11:17 AM UTC
Hi @Vaibhav_Thakare
You can simply use a Validator filter.
You just need to write a code that allows the action in the menu. It is up to you what you want to check.
By code you can check groups roles or any other conditions
PetrH
Feb 5, 2024 11:21 AM UTC
Hi PetrH,
Unable to access the link you shared. Getting below error.
HelesicPetr
Hi @Vaibhav_Thakare
PetrH
