Dec 28, 2021 12:20 PM UTC
How add a prefix to an autogenerated number?
Hello everyone, can you please tell me how can I add a prefix from business attr to an autogenerated number?
How to get this number: ABC.0000185268?
<AttributeValues objType="wt.part.WTPart">
	<AttrConstraint id="number" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
		<Value algorithm="com.ptc.core.rule.server.impl.GetServerAssignedConstraint"/>
	</AttrConstraint>
</AttributeValues>
BenLoosliAnswer
Dec 28, 2021 2:39 PM UTC
Wrong part of the OIR to modify.
Look for:
<!-- set the number to a generated number -->
<AttrValue id="number" algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator">
<Arg>
ABC.
</Arg>
<Arg>
{GEN:wt.enterprise.SequenceGenerator:WTPARTID_seq:10:0}
</Arg>
</AttrValue>
You can put anything you like in the first ARG statement for your prefix and then let the system generate the 10 character number to follow.
BenLoosli23-Emerald IIIAnswer
Look for:
<Arg>
ABC.
</Arg>
<Arg>
</Arg>
</AttrValue>
VladiSlav17-PeridotAuthor
Dec 28, 2021 4:07 PM UTC
, thanks for your reply. It turned out to add constant values. But it does not work, it turns out to add a value from a global attribute (soft attribute or IBA).
Please tell me how this can be done?
Dec 28, 2021 4:14 PM UTC
I tried different ways, but with no result. Here is an example of the final attempt
 <!-- add a V prefix for variant parts -->
 <Value algorithm="wt.rule.algorithm.BooleanBranch">
	 <Value algorithm="wt.rule.algorithm.EqualsTest">
		<Attr id="genericType"/>
		<Arg>variant</Arg>
	 </Value>
	 <Arg>V</Arg>
	 <Arg></Arg>
 </Value>
 <!-- the sequence -->
 <Arg id="IBA|wt.pdmlink.PDMLinkProduct.ИНДЕКС_ТС"/>
 <Arg>{GEN:wt.enterprise.SequenceGenerator:WTPARTID_seq:10:0}</Arg>
</AttrValue>
