Mar 30, 2017 12:19 PM UTC
how can I abandon a running promotion request
I have a running promotion request that I need to abandon or stop so that I can replace an approver with another approver.  My thought was to simply abandon the running workflow and start over.
Mar 30, 2017 1:33 PM UTC
If you created it, just select the PR and delete it.
The files will be returned to their prior state.
Any admin can also do it.
18-Opal
Mar 31, 2017 2:57 AM UTC
If you're just replacing the approver why not simply edit the team?
Apr 4, 2017 4:23 PM UTC
if you have enough access rights:
promotion request action menu: "reassign life cycles", check "Use initial state of Life Cycle template" .
disclaimer: side effects are possible as you are about to terminate the original workflow.
