Feb 4, 2024 3:55 PM UTC
How can I get the "SOFPART" attribute value of the document type object in the promotion?
SOFPART contains multiple string values
I wrote a code to deal with this situation, but the attribute value is empty. Where am I making a mistake?
CODE:
try {
 wt.maturity.PromotionNotice pn = (wt.maturity.PromotionNotice) primaryBusinessObject;
 wt.fc.QueryResult qr = wt.maturity.MaturityHelper.service.getBaselineItems(pn);
 while (qr.hasMoreElements()) {
 java.lang.Object obj=(java.lang.Object)qr.nextElement();
 if (obj instanceof wt.doc.WTDocument) {
 wt.doc.WTDocument wtdoc = (wt.doc.WTDocument) obj;
 wt.content.ContentHolder contentHolder = wt.content.ContentHelper.service.getContents(wtdoc);
 wt.content.ContentItem item = wt.content.ContentHelper.getPrimary((wt.content.FormatContentHolder) contentHolder);
 com.ptc.core.lwc.server.PersistableAdapter persistableAdapter = new com.ptc.core.lwc.server.PersistableAdapter(wtdoc, null, java.util.Locale.getDefault(), new com.ptc.core.meta.common.UpdateOperationIdentifier());
 persistableAdapter.load("SOFPART");
 SOFPART = (java.lang.String) persistableAdapter.get("SOFPART");
} catch (Exception wte) {
 wte.printStackTrace();
HelesicPetr
Apr 3, 2024 1:17 PM UTC
Hi @joe_morton
In his case there is a issue with the retyping the result object.
SOFPART = (java.lang.String) obj2.get("SOFPART");
 If the attribute contains multi values the return object is an array with a string not a String so this is the case why his final variable is empty.
PetrH
avillanueva
23-Emerald II
Feb 4, 2024 6:37 PM UTC
Is "SOFTPART" an IBA on the WTDocument? Or are you trying to get the name a soft typed sub-type of WTDocument? If its an IBA, I can post code for that. Might already be posted. Also looks like you are interrogating the primary content of the WTDocument. Why? Attributes should not be part of the content file.
smcvr15-MoonstoneAuthor
Feb 5, 2024 4:47 PM UTC
Hi @avillanueva,
"SOFTPART" is an IBA in WTDocument
avillanueva
23-Emerald II
Feb 5, 2024 9:15 PM UTC
18-Opal
Apr 3, 2024 5:13 PM UTC
Why not clearly state the problem when you initially post?
Your post is a bit ambiguous.
