6-Contributor
May 27, 2024 6:41 AM UTC
How can we add Iteration note for WTpart using loadfromfile utility
Version: Windchill 12.1
Use Case: To add various comments that are used for the modifying the PArts
Description:
unable to create Iteration comments using XML loadfromfile
d_grahamAnswer
18-Opal
May 30, 2024 11:42 AM UTC
If you really need an iteration note, a note can be added post loadFromFile either via a direct dB edit or it is also possible to add a note using a Java class that uses OOTB Windchill APIs.  And yes, this note can be added without iterating the object,
HelesicPetr
May 27, 2024 8:33 AM UTC
Hi @akshay_r
Unfortunately the loadfromfile utility does not support the iteration comment
Following list is all what you can define based on csvtoxml.txt file for WTPart
BeginWTPart~create~wt.part.LoadPart.beginCreateWTPart~user~partName~partNumber~type~genericType~collapsible~logicbasePath~source~folder~lifecycle~view~variation1~variation2~teamTemplate~lifecyclestate~typedef~version~iteration~enditem~traceCode~organizationName~organizationID~securityLabels~createTimestamp~modifyTimestamp~minRequired~maxAllowed~defaultUnit~serviceable~servicekit~authoringLanguage
EndWTPart~create~wt.part.LoadPart.endCreateWTPart~parentContainerPath
Plus IBA attributes
PetrH
akshay_r6-ContributorAuthor
6-Contributor
May 30, 2024 12:26 PM UTC
Thanks for your Response,
Emeritus
May 30, 2024 10:32 AM UTC
Hello @AR_01_10592119,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
d_graham18-OpalAnswer
18-Opal
HelesicPetr
May 30, 2024 12:02 PM UTC
Yes, Agree with @d_graham
It is possible to edit the iteration note by a customization
PetrH
