Jun 18, 2020 12:31 PM UTC
How do I add an action only for a document subtype?
Hello everyone, please tell me how to add an action to the "Actions" button for only one subtype of the document WTDocument?
hlafkirAnswer
Jun 18, 2020 1:14 PM UTC
Hi
You may check for the property menufor described here :
Defining New Action Model
focus on the "menufor" keyword this point.
Just be aware of the article : CS312920 if this not work, a pre-validation is required.
Sample Code
The following is sample code for an action model that configures a subtype:
<!-- Copied from ChangeManagement-actionModels.xml -->
<!-- Originally copied from menu for wt.change2.WTChangeRequest2 -->
<model name="sample change request actions" menufor="WCTYPE|
wt.change2.WTChangeRequest2|org.default.www.SampleChangeRequest">
<action name="view" type="object"/>
<action name="SETLIFECYCLESTATE" type="pdmObject"/>
<action name="createSubscription" type="subscription"/>
<action name="separator" type="separator"/>
<action name="reviseChangeItems" type="change"/>
<action name="editCapabilityPackage" type="capabilityPackage"/>
<action name="create" type="approach" />
<action name="create" type="capabilityImplementationProject" />
<action name="sandboxAddToProject" type="object"/>
<action name="SBAddToPrj" type="sandbox"/>
<action name="removeShare" type="object"/>
<action name="ManageSecurity" type="accessPermission"/>
<action name="renameObjectWizard" type="object"/>
<action name="delete" type="object"/>
<action name="discuss" type="forum"/>
<action name="copy" type="object"/>
</model>
good luck !
3-Newcomer
Jun 18, 2020 12:56 PM UTC
You need to implement your own custom validator or filter.
hlafkir5-Regular MemberAnswer
Hi
Sample Code
</model>
good luck !
VladiSlav17-PeridotAuthor
Jun 18, 2020 1:20 PM UTC
hlafkir ,Thank you very much, this is what you need
Sep 13, 2024 9:53 AM UTC
Hi VladiSlav, did this work for you?? i tried the same for one of the document subtype dint work, so need your suggestion
