How do I link two Document subtypes?
Hi, everybody!
I have created a subtype of the Document using the following code:
package com.acme;
import wt.doc.WTDocument;
import wt.util.WTException;
import com.ptc.windchill.annotations.metadata.*;
@GenAsPersistable(superClass=WTDocument.class,
 properties={
 @GeneratedProperty(name="sizeC",
 type=Integer.class, initialValue="3",
 javaDoc="Integer value to represent the size of C.")},
 iconProperties=@IconProperties(standardIcon="netmarkets/images/stop.gif",
 openIcon="netmarkets/images/stop.gif")
public class AcmeModeledDoc extends _AcmeModeledDoc {
 static final long serialVersionUID = 1;
 public static AcmeModeledDoc newAcmeModeledDoc()
 throws WTException {
 AcmeModeledDoc instance = new AcmeModeledDoc();
 instance.initialize();
 return instance;
Everything works , I can create a document, specify the sizeС.
I tried creating a second subtype with link it to the previous one:
package com.acme;
properties={
@GeneratedProperty(name="sizeTwo",
 javaDoc="Integer value to represent the size of C."),
// link
@GeneratedProperty(name="sizeC", type=AcmeModeledDoc.class)},
iconProperties=@IconProperties(standardIcon="netmarkets/images/start.gif",
 openIcon="netmarkets/images/start.gif")
public class AcmeModeledDocTwo extends _AcmeModeledDocTwo {
	 public static AcmeModeledDocTwo newAcmeModeledDocTwo()
		 AcmeModeledDocTwo instance = new AcmeModeledDocTwo();
	 return instance;
But now I can 't create a document
Can you tell me how to set up a connection?
