Aug 3, 2023 12:49 PM UTC
How to Achieve Major and Minor revision on Part in Windhcill 12
Do we need customization for Major and Minor revision or there is an OOTB feature in windchill 12.
HelesicPetr
Aug 8, 2023 7:42 AM UTC
Hi @AP_10483126
Yes, you need a customization. U would recommend you to convince customer to go different way.
PetrH
avillanueva
23-Emerald II
Aug 3, 2023 2:18 PM UTC
Just so we are clear, how would you define the difference between major and minor revisions?
Aug 3, 2023 4:38 PM UTC
Major Revision : When there are major changes and this needs to be sent to the supplier.
Minor Revision : When there are simple changes to perform but the revision doesn't need to be communicated to supplier.
avillanueva
23-Emerald II
Aug 3, 2023 4:50 PM UTC
My 2 cents would be to not over complicate things. A revision is a revision is a revision. Just to be clear that we are not talking about FFF which should change part number.  I would and do handle this in the change process. I have a type of technical and non-technical change. They are all still revisions but you can work into the process that if its is a non-technical change (minor), it would not trigger those working with a supplier to do anything.
