How to add custom IBA on Where Used Table Builder
Hi All,
I want to add the custom IBA like Plant Revision on Where Used Table Builder , could you please provide the detail code.
Vishvanatha
18-Opal
Please refer to the following article.
https://www.ptc.com/en/support/article/CS139619?source=search
Is Plant Revision attribute unavailable in the Available Columns section when customizing the table view through the UI?
