6-Contributor
Sep 18, 2023 12:13 PM UTC
How to add custom jar references to Workflow and LifeCycle JNLP
Hello everyone!
I've made changes to libs folder and moved some jars to another directory.
Is there a way to add some custom jars to the JNLP constructor when I open the edit action on Workflow Template Administration?
When I edit the JNLP file and manually add the jar files, this works perfectly. But, I want to generate these jnlp files with this jar files included.
I use Windchill 11.
Apr 15, 2024 8:15 AM UTC
e.g. %WT_HOME/codebase/WEB-INF/lib
HelesicPetr
Apr 11, 2024 10:54 AM UTC
HI @leoffabris
If I want to use external library I just add the jar file to java path or custom specific folder. Windchill load this jar file on the start of the method server.
The jars are listed in the method server log.
PetrH
