How to add information button in table builder to show the information about that object
I have added this but not working
ColumnConfig c6= ccf.newColumnConfig("infoPageAction", true); //for i button
c6.setInfoPageLink(true);
c6.setDefaultSort(true);
tc.addComponent(c6);
HelesicPetr
Hi @RS_10128209
Something has to be wrong in your code.
create columnconfig is correct. Add the compotnent to the table config is correct.
why do you try to sort by an infobutton?
Following example works for me perfectly.
tableConfig.addComponent(configFactory.newColumnConfig("infoPageAction", true));
try to debug the code by stopping the method line by line and control what is in tableConfig object
PetrH
Thanks @HelesicPetr for reply
but its creating blank column with only name
HelesicPetr
Hi @RS_10128209
What version do you use?
What kind of object is show in the table? is it your type or some general type?
Is it Link object or is it normal object as WTPart.
Depends on your configuration. I guess that you will need to define own DataUtility which creates correct information button because OOTB DU can not find correct object to build the button.
PetrH
