May 2, 2018 10:39 AM UTC
How to add Max function QuerySpec
I trying to create a QuerySpec to retrieve highest branchIditerationInfo (using MAX function) value to get the latest most object
Ankit
May 8, 2018 3:12 PM UTC
You do something similar to the following:
QuerySpec subSelect = new QuerySpec();
subSelect.setAdvancedQueryEnabled(true);
ClassAttribute versionSortId = new ClassAttribute(WTPart.class, "versionInfo.identifier.versionSortId");
SQLFunction maxFunction = SQLFunction.newSQLFunction(SQLFunction.MAXIMUM, versionSortId);
subSelect.appendSelect(maxFunction, new int[]{wtPartIndex}, false);
This should get you headed in the right direction.
ShirishMorkhade
May 30, 2018 6:31 PM UTC
Hello Ankit,
Windchill help center has nice elaboration about SQLFunction here at
http://support.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=WCCG_Serv_AdvQuery_SearchCondition&action=show
This contains an example of SQLFunction.MINIMUM but it will more or less identical for SQLFunction.MAXIMUM.
I hope this will help you in what you want to achieve.
Shirish
