Apr 18, 2016 1:32 PM UTC
How to attach a Part to a Document using Windchill API ?
Hi All,
How do we attach a WTPart or a WTDocument to a WTdocument in the related objects using API ?
Can anyone tell like which API is used exactly ?
Thanks in Advance,
Aditya
aachanta15-MoonstoneAuthor
Apr 18, 2016 1:56 PM UTC
Like inserting a document in the sense.
WTDocument -> Information Page -> Related Objects ->
So how do we add a Where Used Document  or References Document or Referenced By Documents or Parts using Windchill API.
Kindly let me know the solution if anyone is aware of it.
Thanks and Regards,
Aditya Achanta
Apr 19, 2016 12:58 PM UTC
Please refer to the API Below :-
ReferencedBy
WTDocument workable = (WTDocument)WorkInProgressHelper.service.workingCopyOf(doc);
wt.doc.WTDocumentDependencyLink  dependlnk= wt.doc.WTDocumentDependencyLink.newWTDocumentDependencyLink(workable,referenceddoc);
PersistenceServerHelper.manager.save(dependlnk);
UsedBy
WTDocumentUsageLink usage_link = WTDocumentUsageLink.newWTDocumentUsageLink(parent_document,(WTDocumentMaster)child_document.getMaster());
usage_link.setStructureOrder(0);
PersistenceServerHelper.manager.save(usage_link);
Aditya
Apr 20, 2016 5:02 AM UTC
Hi Aditya,
Thank you.
But how about attaching a WTPart -DESCRIBES PARTS for a WTDocument in Related Objects ?
Can you please suggest API even for that ?
Thanks and Regards,
Aditya
Apr 26, 2016 3:17 PM UTC
Hi Aditya,
Sorry for the late response, you can probably use :-
if(!WorkInProgressHelper.isWorkingCopy(wtpart))
this checks if the WTPart instance under consideration is the workingCopy, if not then Checkout.
Aditya
Apr 28, 2016 9:45 AM UTC
Thanks Aditya.
I got it.
Best Regards,
Aditya
