Feb 15, 2017 10:31 AM UTC
how to build a custom utility to import BOM?
Hi
I am building a utility to import BOM in customer format.
Requirement is:--
1. User will upload BOM in CSV format.
2. User can preview CSV in HTML and validate before uploading to windchill.
3. CSV wont be uploaded or lets say BOM wont be uploaded if there is any error in Line item.
4. Result of Upload Process should appear against CSV rows in HTML.
Please suggest.
//Rakesh
Feb 20, 2017 10:39 AM UTC
Hi Rakesh,
so you'll have to identify the part you want to link, export the structures (with expected config) from Windchill and build the part structure in your tool for the display before validation (pre-run).
For building your merged structure (windchill + what you want to import), you'll need some strategy. The most common would be either to replace the existing links, or only add new links...
Something you could consider is whether to create a baseline object from your import or not. It can be usefull to trace which version of the part were imported.
Loïc
rkumar-101-VisitorAuthor
Feb 21, 2017 4:29 AM UTC
Hi Loïc
Thanks for the base line Idea.
I want to build logic only to update usage attributes value for existing link. UsageLink wont be created or deleted.
I cant figure out how to show error result on back to CSV upload page.
Steps are:--
  1. Upload CSV in HTML
  2. Preview and Validate with javaScript for input fields.
  3. Highlight error cells.
  4. How to Disable Ok wizard Button if CSV is not valid.
  5. Ok button will sumit wizard for processing.
  6. How to Highlight or Mark rows with error after Processing in same html load csv page?
Thank in advance for help. 🙂
//Rakesh
2-Explorer
Feb 21, 2017 2:54 AM UTC
I don't know whether you already looked at what is available out of the box - Importable spreadsheets - http://support.ptc.com/cs/help/windchill_hc/wc110_hc/index.jspx?id=WPCOverview&action=show/ Import from Excel
Feb 21, 2017 4:58 AM UTC
Hi Binesh
we have explored this but we have specific format through which user will update BOM.
//Rakesh
Feb 22, 2017 4:15 PM UTC
Rakesh,
The import from spreadsheet functionality is customizable, I believe you can extend this as per your import format instead writing whole new codes.
