8-Gravel
How to call a form processor on a wizard jsp which is not being called from an action
I have created a data utility on an attribute which opens a jsp when clicked. Now in this jsp i've created a wizard and added a wizard step. In the wizard step I have 2 table builders, so when i click on the Ok button i want to get the selected objects. But I'm unable to call a form processor on this wizard.
18-Opal
Hi @OP_11714882,
I wanted to understand your use case. Is there a specific reason for having two Table Builders?
Which selected objects of the two Table Builders are you intending to pass back?
8-Gravel
I created the data utility on a part attribute and it shows me table builders for Described By Documents and Reference Documents. So I want to pass only the selected documents in these to tables.
HelesicPetr
Hi @OP_11714882
How do you register your wizard?
You should define the processor in a custom-Action.xml file
 <action name="SPackageWizard">
 <label>Send to ZIP</label>
 <title>Send to ZIP</title>
 <tooltip>Send to ZIP</tooltip>
 <icon>package_zipped.gif</icon>
 <command method="export"
 class="com.my.SPackage.SPackageProcessor"
 url="netmarkets/jsp/com/my/SPackage/SPackageWizard.jsp"
 windowType="popup"/>
 <includeFilter name="hideSPackageValidator"/>
</action>
PetrH
