Part Configurations take their information from the Part they are created from. If you make a configuration from a Part with a Design view the Part Configuration will be Design View. If you make a Part Configuration from a Part in a Manufacturing view the Part Configuration will have a Manufacturing View.
Part Configurations are only meant to hold the configuration (eg Version, View) of Parts used to generate or update a Product Instance. They are not meant for interaction beyond that use case.
