It's not clear to me exactly what you want to do, but here's a couple ideas:
  1. Replace codebase/netmarkets/images/logoWC.png
  2. Edit codebase/index.html and replace img tag src attribute OR replace codebase/wtcore/images/bblks/l_ptc_splash.gif or codebase/wtcore/images/bblks/l_ptc_splash.png
If that doesn't help:
  • What version of Windchill are you on
  • What exactly do you want to change or replace (screenshot might help if you're unsure how to explain).
amitshah1-VisitorAuthor
I want to change the default PTC Windchill logo from the Windchill page.
I tried replacing image from by thru codebase/netmarkets/images/logoWC.png but no luck.
Try clearing your Tomcat cache maybe? Restart Method Server?  Or maybe a hard refresh (Guessing CTRL+F5) in your browser?
If that fails (I'm not sitting in front of a WC instance to check), but maybe open up the DOM inspector in your browser and find out what image that element points to.
Also look here:
<Windchill>/codebase/netmarkets/images/ptclogo.gif
<Windchill>/codebase/netmarkets/images/linklogo.gif
- OR -
From Document CS24738‌ , which mentions WC 10.0 HC Customizing UI Branding,
try:
1. Create <WT_HOME>/codebase/ext directory :
  • Place the logo file logo.png in this directory
  • Create custom.css in this directory with the following content:
#logoNav.wncApplLogo { background-image: url(logo.png); }
#logoNav.pjlApplLogo{ background-image: url(logo.png); }
#logoNav.pdmlApplLogo{ background-image: url(logo.png); }
​​Note :  the image url path is relative to the custom.css location.
2. Register the custom.css :
  • Add to site.xconf :
<Property name="netmarkets.presentation.cssFiles" overridable="true" targetFile="codebase/presentation.properties" value="ext/custom.css"/>
  • Deploy with xconfmanager -p
  • Restart Windchill
7-Bedrock
Hello Team,
How can I change the Windchill header logo and UI Logo in Windchill 12.0.0.0? I have followed the article mentioned above, but I am unable to set the correct dimensions, and the image quality appears low.
avillanueva
23-Emerald II
In future, try not to reply to old threads. I replace the logo by overwriting this file with my own image.
<Windchill>/codebase/netmarkets/images/logoWC.png
Mine is 136x30 pixels.
