8-Gravel
January 16, 2023
How to check if downstream view of the WT part exists?
Hi All,
I want to create a "Manufacturing" view for the part included in the Change task, but I want to do it only if it doesn't exist.
Now I use this code without checking. And I want to add something like " if Manufacturing view for obj ==null then"
wt.fc.QueryResult qr = wt.change2.ChangeHelper2.service.getChangeablesBefore((wt.change2.ChangeOrderIfc) primaryBusinessObject);
while(qr.hasMoreElements())
  wt.fc.WTObject  obj =(wt.fc.WTObject) qr.nextElement();
   if(obj instanceof wt.part.WTPart)
       wt.part.WTPart prt = (wt.part.WTPart) obj;
       wt.part.WTPart ManufPart = (wt.part.WTPart)
       ManufPart = (wt.vc.views.ViewManageable)obj, "Manufacturing")
       wt.vc.views.ViewHelper.service.newBranchForView((wt.vc.views.ViewManageable)obj, "Manufacturing");
      ManufPart = (wt.part.WTPart)wt.fc.PersistenceHelper.manager.store(ManufPart);
HelesicPetr
Hi @Dina_S
It is easy.
Filter the results based on your view
QueryResult qrUstr = PersistenceHelper.manager.navigate(part,EquivalenceLink.DOWNSTREAM_ROLE,wt.associativity.EquivalenceLink.class, true);
		WTPart dwWTP = null;
		while (qrUstr.hasMoreElements())
			dwWTP = (WTPart) qrUstr.nextElement();
			if (dwWTP.getViewName().equalsIgnoreCase("manufacturing"))
				System.out.print(dwWTP.getNumber()); // use it as you need.
PetrH
Dina_S8-GravelAuthor
8-Gravel
January 17, 2023
I have found this
https://www.ptc.com/en/support/article/cs47538?language=en&posno=4&q=ViewHelper.service.newBranchForView&source=search
wt.fc.PersistenceHelper.manager.navigate(reference.getObject(),wt.associativity.EquivalenceLink.DOWNSTREAM_ROLE, wt.associativity.EquivalenceLink.class);
I need help finding out how to use this. I need only the "Manufacturing view" part, not the "Service view" one. And I don't know how to check the assigned view for the object. I would really appreciate it if someone could help me.
So I tried this and it doesn't work like I want:
wt.fc.QueryResult AllDownPart = wt.fc.PersistenceHelper.manager.navigate(obj,
wt.associativity.EquivalenceLink.DOWNSTREAM_ROLE, wt.associativity.EquivalenceLink.class,true);
if(AllDownPart != null){
HelesicPetr
Hi @Dina_S
It is easy.
PetrH
8-Gravel
January 18, 2023
Thank you for the clue.
