How to convert CSV file to XML to import a classification structure in windchill 12
To create a classification structure by importing a csv template.
HelesicPetr
Hello @RS_10128209
There is a windchill shell tool to convert csv to xml (wt.load.util.CSV2XML)
first you should prepare CSV file based on a csvmapfile.txt (WT_HOME\loadFiles\csvmapfile.txt)
there are method you need.
save csv to D:\IMPORTCSV
then use windchill shell command
windchill wt.load.util.CSV2XML -root D:\IMPORTCSV
 XML file will be generated and this file you can load to Windchill by
windchill wt.load.LoadFromFile -u AdminUser -p AdminPassword -d D:\IMPORTCSV/sourceFile.xml -CONT_PATH \"/ORG_NAME/wt.pdmlink.PDMLinkProduct=PRODUCTNAME\"
 Hope this can help
PetrH
Im enable to convert CSV to XML file its showing me the error related to header.
Curious if you got this working?  In my searches I'm seeing mixed information on if CSV2XML works for Classification structures.
18-Opal
It’s all in the help.
The process is very simple.
Did you not read the manual?
