18-Opal
June 20, 2023
How to create a queue through load from file?
I was wondering if there is any load file available to load custom queue
Fadel
23-Emerald II
June 21, 2023
No this is not possible using data load , see https://www.ptc.com/en/support/article/CS306576
Buiꓘa
18-Opal
June 21, 2023
You could certainly create custom queues by writing a Java class to do it that uses the Windchill APIs,
That should be no problem to get done.
HelesicPetr
Hi @TDT
as @d_graham mentioned
if you use custom Queue you definitely use own custom code.
So just create the queue in your function before you add a entry to a queue.
If the queue exists add entry, else create queue.
PetrH
