Feb 11, 2020 11:38 AM UTC
How to create and render custom table for non persistable object in windchill?
I am able to create MVC table builder for non persistable object, but records are not displaying in table,
hence can anyone provide solution?
FYI : "extends AbstractConfigurableTableBuilder"
Thanks.
Feb 11, 2020 2:03 PM UTC
mohitenw12-AmethystAuthor
Feb 12, 2020 4:51 AM UTC
Thanks Shriram,
i am able to create table but stuck in populate data.
Rows created but data not display.
Feb 12, 2020 5:30 AM UTC
Have you added the oid column?
columnConfig = componentConfigFactory.newColumnConfig("oid", "oid", false);
columnConfig.setDataStoreOnly(true);
tableConfig.addComponent(columnConfig);
Feb 11, 2020 3:10 PM UTC
You need to provide an attribute called oid in your java object. Than you will be able to show any object in a table.
If you need your own views than you can extend the table as you did, otherwise AbstractComponentBuilder does work also.
Feb 12, 2020 6:39 AM UTC
Hello, there is a video of training for example from the documentation
https://www.youtube.com/watch?v=-14BSAwteVw&list=PLjm4gmbLQwoeqQSP7xUhCnInGknqTBAZV&index=2
