How to create Custom REST END Point to create Options and Variants and assign it to a specific Part
I am exploring the feasibility of developing a unified REST endpoint that enables the creation of Options and Choices, associates an Option Set with a Product under an Option Pool, and assigns it to a specific configurable WTPart. This endpoint would also facilitate the creation of a Variant Specification. While these actions are currently performed through multiple steps in the Windchill UI, my goal is to streamline the process into a single interface. This would allow users from non-Windchill platforms to access a Product and its associated WTPart, input specific Options and Choices, and generate a Variant BOM accordingly. I seek expert guidance on the feasibility and potential challenges of implementing this approach.
HelesicPetr
Hi @AKC_301264
Here is an example how to create own custom rest api method.
in the java class you just have to write a code that do what you need. This example shows just update Primary Conent Of a Document by rest api
1. ptc\Windchill_12.0\Windchill\codebase\rest\custom\domain\DocMgmt\v5\import.js
function action_updatePrimaryConentOfDocument(data, params) {
 var doc = Java.type('ext.sconce.solution.ODataHelper');
 return doc.updatePrimaryConentOfDocument(data, params);
2. ptc\Windchill_12.0\Windchill\codebase\rest\custom\domain\DocMgmt\v5\import.json
"actions" : [
 "name": "updatePrimaryConentOfDocument",
 "importName": "updatePrimaryConentOfDocument",
 "description": "API to update update Primary Content Of WTDocument & remove existing content",
 "includeInServiceDocument": true,
 "parameters": [
 "name": "Number",
 "type": "String",
"isNullable": false,
"isCollection": false
 "name": "fileLocation",
 "type": "String",
 "name": "fileName",
 "type": "String",
 "returnType": {
 "type": "Edm.String",
 "isCollection":false,
"isNullable": true
Input:
fileLocation: D:\TestUploadFolder
Number      : 0000001112
fileName    : fileExample.pdf
3. Java file:
package ext.sconce.solution;
import java.beans.PropertyVetoException;
import java.io.File;
import java.io.FileInputStream;
import java.io.IOException;
import java.util.HashMap;
import java.util.Map;
import org.apache.logging.log4j.Logger;
import org.apache.olingo.commons.api.data.Parameter;
import org.apache.olingo.commons.api.http.HttpStatusCode;
import org.apache.olingo.server.api.ODataApplicationException;
import org.json.JSONObject;
import com.flexnet.lm.binary.StringUtil;
import com.ptc.odata.core.entity.action.ActionProcessorData;
import com.ptc.odata.core.entity.property.EntityAttribute;
import com.ptc.odata.core.entity.property.PropertyValueType;
import wt.content.ApplicationData;
import wt.content.ContentHelper;
import wt.content.ContentHolder;
import wt.content.ContentItem;
import wt.content.ContentRoleType;
import wt.content.ContentServerHelper;
import wt.doc.WTDocument;
import wt.fc.QueryResult;
import wt.log4j.LogR;
import wt.pds.StatementSpec;
import wt.pom.Transaction;
import wt.util.WTException;
import wt.util.WTProperties;
import wt.util.WTPropertyVetoException;
public class ODataHelper {
private static String CLASSNAME = ODataHelper.class.getName();
private static Logger logger = LogR.getLoggerInternal(CLASSNAME);
public static EntityAttribute updatePrimaryConentOfDocument(ActionProcessorData data,
HashMap<String, Parameter> params) {
if (logger.isDebugEnabled())
logger.debug(CLASSNAME + " - updatePrimaryConentOfDocument Start");
Map<String, Object> responseMap = new HashMap<String, Object>();
String fileName = "";
String Number = "";
String fileLocation = "";
try {
Number = getStringParameter(data, params, "Number");
fileLocation = getStringParameter(data, params, "fileLocation");
fileName = getStringParameter(data, params, "fileName");
logger.debug("Number:" + Number + "fileLocation" + fileLocation + "fileName " + fileName);
updatePrimaryConentOfDocument(Number, fileLocation, fileName);
responseMap.put("Message", "update Primary Conent Of Document successfully.");
} catch (ODataApplicationException e) {
e.printStackTrace();
responseMap.put("Error", e.getMessage());
EntityAttribute result = new EntityAttribute(null, "values", PropertyValueType.PRIMITIVE,
new JSONObject(responseMap));
return result;
public static String getStringParameter(ActionProcessorData data, Map params, String stringName)
throws ODataApplicationException {
StringUtil.isEmpty("");
Parameter param = (Parameter) params.get(stringName);
if (org.springframework.util.StringUtils.isEmpty(param.getValue())) {
String errorMsg = "Invalid Parameter - " + stringName + "not found in the request";
throw new ODataApplicationException(errorMsg, HttpStatusCode.BAD_REQUEST.getStatusCode(), data.getLocale());
} else {
return (String) param.getValue();
public static void updatePrimaryConentOfDocument(String Number, String fileLocation, String fileName) {
logger.debug("updatePrimaryConentOfDocument - replaceContent - BEGIN");
WTDocument wtdoc = getDocumentByNumber(Number);
if (wtdoc != null) {
Transaction trx = new Transaction();
try {
trx.start();
ApplicationData wtdContent = ApplicationData.newApplicationData((ContentHolder) wtdoc);
wtdContent.setFileName(fileName);
wtdContent.setRole(ContentRoleType.PRIMARY);
WTProperties wtproperties = wt.util.WTProperties.getLocalProperties();
String dirSeparator = wtproperties.getProperty("dir.sep");
logger.debug("Path : " + fileLocation + dirSeparator + fileName);
File file = new File(fileLocation + dirSeparator + fileName);
wtdoc = (WTDocument) wt.vc.VersionControlHelper.service.getLatestIteration(wtdoc, true);
deletePrimaryContent(wtdoc);
try (FileInputStream istream = new FileInputStream(file)) {
ContentServerHelper.service.updatePrimary(wtdoc, wtdContent, istream);
istream.close();
ContentServerHelper.service.updateHolderFormat(wtdoc);
logger.debug("Replaced content - wtdoc: " + wtdoc.getIdentity());
trx.commit();
trx = null;
logger.debug("Completed updatePrimaryConentOfDocument END");
} catch (WTException | PropertyVetoException | IOException ex) {
System.out.println(
" Error while updating primary content = " + ex + "for WTDocument " + wtdoc.getIdentity());
ex.printStackTrace();
} finally {
if (trx != null) {
trx.rollback();
public static WTDocument deletePrimaryContent(WTDocument wtdoc) {
try {
QueryResult qrCI = ContentHelper.service.getContentsByRole((ContentHolder) wtdoc, ContentRoleType.PRIMARY);
if (qrCI.size() > 0) {
ContentItem ci = (ContentItem) qrCI.nextElement();
ContentServerHelper.service.deleteContent(wtdoc, ci);
} catch (WTException | WTPropertyVetoException ex) {
return wtdoc;
public static WTDocument getDocumentByNumber(String docNumber) {
WTDocument doc = null;
try {
wt.fc.QueryResult result = null;
wt.query.QuerySpec query = new wt.query.QuerySpec(WTDocument.class);
wt.query.WhereExpression condition1 = new wt.query.SearchCondition(WTDocument.class, WTDocument.NUMBER,
wt.query.SearchCondition.EQUAL, docNumber);
int fromIndices[] = { 0, 1 };
query.appendWhere(condition1, fromIndices);
result = wt.fc.PersistenceHelper.manager.find((StatementSpec) query);
while (result.hasMoreElements()) {
doc = (WTDocument) result.nextElement();
} catch (Exception e) {
return doc;
hope this can help how to create own RestApi function.
PetrH
Hello Petr,
Thank you for your time and valuable response. While I am familiar with developing custom REST endpoints, I am specifically seeking guidance related to Options and Variants. For instance, I am trying to assign an Option Set to a Configurable Part, but I have not been able to find any relevant API for this purpose. Any assistance in this regard would be greatly appreciated
Hello Petr,
Thank you for your response and for sharing the custom REST/OData implementation example.
I have already implemented a custom OData action that successfully attaches secondary content to a WTDocument when a file path accessible to the Windchill server is provided.
My question is specifically related to file uploads from external client applications. In the current approach, the API accepts a server-side file path, for example:
"DocumentNumber": "0000000048",
"FilePath": "E:\\Files\\Test.pdf"
This works only when the Windchill server has direct access to the file location.
However, my requirement is to allow a client application to upload a physical file that exists only on the client machine and attach it as primary or secondary content to a Windchill object. The Windchill server would not have direct access to the client's filesystem.
Could you please advise whether Windchill custom OData actions support receiving file content through multipart/form-data or any other mechanism for transferring binary content directly from the client to the Method Server? If not, is there a PTC-recommended approach, API, or sample implementation for handling client-side file uploads and attaching them to Windchill content objects?
Any guidance or documentation references would be greatly appreciated.
Thank you.
