Aug 24, 2017 1:54 PM UTC
How to create subtype of WTDocument by API?
We can use API to create new WTDocument, but we have a subtype under WTDocument, how can I create a subtype by API? Who could help me? Thanks in advanced.
20-Turquoise
Aug 24, 2017 2:30 PM UTC
I know of 2 ways to do this. Method 1 where you find the TypeDefinitionReference and set the doc type and method 2 by using the PersistableAdapter.
Method 1:
//find the TypeIdentifier
TypeIdentifier myCustomType = TypeHelper.getTypeIdentifier("WCTYPE|wt.doc.WTDocument|com.mydomain.Document.myCustom");
//cast to WCTypeIdentifier
WCTypeIdentifier myCustomWCType = (WCTypeIdentifier) myCustomType;
//find the TypeDefinitionReference
TypeDefinitionReference myCustomTDR = TypedUtilityServiceHelper.service.getTypeDefinitionReference(myCustomWCType.getTypename());
//create doc
WTDocument doc = WTDocument.newWTDocument();
//set the doc TypeDefinitionReference
doc.setTypeDefinitionReference(myCustomTDR);
Method 2:
//Use the PersistableAdapter
PersistableAdapter obj = new PersistableAdapter("com.mydomain.Document.myCustom", locale, new CreateOperationIdentifier());
20-Turquoise
Method 1:
//create doc
Method 2:
WhiteChen1-VisitorAuthor
Aug 25, 2017 2:19 AM UTC
Hi Randy,
Appreciate your answer, your code is worked for me. One more question, how can I fill up the attributes when the document is created? The cutomized attributes as picture show.
Thanks.
20-Turquoise
Aug 25, 2017 2:25 PM UTC
@WhiteChen wrote:
Hi Randy,
Check out this PTC article and keep in mind that LWCNormalizedObject has been replaced with PersistableAdapter
https://www.ptc.com/en/support/article?n=CS135663
