How to customize Promotion Request task subject in UI
Hi All,
Is there any api to customize content of Subject of Promotion Request Task?? I was able to change Subject of emaill notyfication. Now I need to do this same i UI.
Thank you in advance for any advice.
Catalina
Community Manager
Hi @Gucio
Thank you for your question!
Best regards,
Catalina | PTC Community Manager
18-Opal
@Gucio ,
It is doable to change the OOTB task 'Subject' in the UI.  See image below.
As you can see. ONLY tasks from Promotion Request workflows will get the added text.
You never stated EXACTLY how you wanted to change the OOTB display of the task 'Subject' so I just added some static text to show it can be done.
David
Gucio16-PearlAuthor
I will try to explain in more details.
For Promotion Request email notification subject - I've modified General*.html files from codebase\templates\workNotification. As a result new mail subject contains some variable taken from Promotion Request workflow. My gol is to have this same subject for task in UI. Can you guide me what should I do?
Gucio
18-Opal
@Gucio ,
Can you tell me the name, display name and data type of each of the variables and EXACTLY how you want them to appear in the 'Subject'?
Are you keeping the OOTB Subject display and simply appending the variable to it?
Do you want the variable to be at the start of the 'Subject'?
Please be very clear with EXACTLY how you want the 'Subject' to appear.
A screenshot of your workflow variables and exactly which ones should appear and where/how they should appear in the 'Subject' would be helpful.  This would eliminate anymore back and forth on questions on my part.
