7-Bedrock
How to Enable confirmation pop-up while Reject the task in worflow?
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.6
We want to enable confirmation pop-up (OK or CANCEL) by selecting reject routing option in workflow.
Here are the errors that I faced
How to enable confirmation pop-up instead of warning message?
    Article - "How to display a confirmation popup at the end of a customized wizard rather than an Inline Message in Windchill": https://www.ptc.com/en/support/article/CS151142
    HelesicPetr
    Hi @vshanmugam
    You can use the Article CS44140 to add an alert for the complete task button.
    Instead of alert I recommend to use a confirm("Do you want to continue ?");
    next you can use also js functions to get the page information what has been selected so you can put a condition if the confirm message should be shown or not.
    here is an example how to use the confirm function How to use JavaScript to show a confirm message.
    PetrH
