How to find Deprecated API ?
Is there a way I can find all the Deprecated API in Windchill 11 & Windchill 12 Programmatically ?
avillanueva
23-Emerald II
September 22, 2022
Typically an IDE like Eclipse and Netbeans will note when you've used a deprecated API with some warning or indicator. Not every class/method is documented in the Windchill JavaDoc but there are some notes there too.
vlmadala10-MarbleAuthor
Yes .That's right . However, when the codebase is larger, going through it to identify the deprecations needs some time. If any utility that will scan the code and generate a report comparing to the required  target , will be helpful .
HelesicPetr
Hi @vlmadala
Why? Many Windchill classes are marked as deprecated for ages but they are still there. From version 9 to 12.
PetrH.
@HelesicPetr  Windchill 12 has removed all the deprecated classed that were in use till WIndchill 11
HelesicPetr
Hi @vlmadala
I don´t think so  May be some of them not all.
PetrH
