6-Contributor
How to generate Downstream Part Thumbnail
Hello.
If Downstream is created using OOTB's BOM Transformer, Thumbnail is created in the Downstream Part, but if it is created in Java using the Windchill API, Thumbnail is not created.
Create a Downstream Part using the Windchill new BranchForView API.
When you create a Downstream Part, the thumbnail of the part created is not visible.
Upstream Part has Thumbnail.
I'm looking for a way to make the Downstream Part show Thumbnail.
A little bit of information is good, so please share it.
Thank you in advance.
Fadel
FadelAnswer
23-Emerald II
Are you using something like below to create the EQL bnetween EBOM/MBOM :
EquivalenceLink link1 = EquivalenceLink.newEquivalenceLink(part,mPart);
link1.setIsConsumable(true);
link1.setUpstreamContextRef(part.getView());
link1.setDownstreamContextRef(mPart.getView());
link1 = (EquivalenceLink) PersistenceHelper.manager.save(link1);
Buiꓘa
Fadel
Fadel23-Emerald IIAnswer
23-Emerald II
Buiꓘa
6-Contributor
That's right.
After creating Downstream with new BranchForView, we are doing equivalenceLink between objects with equivalenceLink.
I can't see the thumbnail even if I connect the equivalence Link
Fadel
23-Emerald II
Can you enable below loggers to TRACE and share the logs as transformation is done from UI and API to compare .
com.ptc.windchill.associativity.copyover.CopyOverPropertiesParser
com.ptc.windchill.associativity.transform.copyover.ClassicTransformCopyOverDelegate
com.ptc.windchill.associativity.copyover.DefaultAttributesCopyOverDelegate
com.ptc.windchill.associativity.copyover.CopyOverData
Buiꓘa
