how to get data from OData from within JSP
Team
Is it possible to GET OData data from within JSP code? It would GET from the local Windchill (localhost).
Do I have an authentication problem?
rleir17-PeridotAuthor
Petr:
As for authentication, I can see how in the JSP to get the username. Is the usr:pwd needed in the OData URL when the call is within Windchill?
cheers -- Rick
HelesicPetr
Usually you need login with a password to open new session.
I would say if you communicate with windchill you need to authenticate.
PetrH
