How to get (lifecycle)state of a WTDocumentMaster object?
There is a BOM structure. The condition is that before a child is not at its RELEASED state, Parent cannot be released.
I have used  wt.doc.WTDocumentHelper.service.getUsesWTDocumentMasters() to get the child document.
I want to get the state of the child document. SO I used,
                              WTDocumentMaster childPart = (WTDocumentMaster) childInfo;
                               wt.lifecycle.State childState = ((_LifeCycleManaged) childPart).getLifeCycleState();
ERROR is -> wt.doc.WTDocumentMaster cannot be cast to wt.lifecycle._LifeCycleManaged
I cannot get the state of the object. The above function does not work for WTDocumentMaster. Neither does object.getState().
How should I fetch the state of the object??
I haven't looked at the vc or lifecycle packages in a while, so I'm sure there's a better way, but the comparator was fun to write.
// get your master
final WTDocumentMaster master = (WTDocumentMaster)new ReferenceFactory().getReference("xxxxxxxx").getObject();
// add latest iteration of each version to list
final List<WTDocument> list = new ArrayList<>();
final QueryResult versions = VersionControlHelper.service.allVersionsOf(master);
while(versions.hasMoreElements()) {
  list.add((WTDocument)versions.nextElement());
// sort list, latest version first
Collections.sort(list,new Comparator<WTDocument>() {
  @Override
  public int compare(final WTDocument o1,final WTDocument o2) {
  try {
  final MultilevelSeries o1Series = VersionControlHelper.getVersionIdentifierSeries(o1);
  final MultilevelSeries o2Series = VersionControlHelper.getVersionIdentifierSeries(o2);
  if(o1Series.equals(o2Series)) {
  return 0;
  if(o1Series.greaterThan(o2Series)) {
  return 1;
  return -1;
  } catch(final VersionControlException e) {
  // it's up to you
  return 0;
// you're done
final WTDocument latest = list.get(0);
final State state = latest.getLifeCycleState();
ash1-VisitorAuthor
It helped. Thanks!
