How to get Non Latest Linked Upstream WTPart via API when the Equivalence Link is not updated
I have a scenario where I need to traverse to to the Upstream eBOM part using following API -> wt.fc.PersistenceHelper.manager.navigate(mfg_Part,
wt.associativity.EquivalenceLink.UPSTREAM_ROLE, wt.associativity.EquivalenceLink.class);
Above API returns QueryResult for all iterations of upstream WTPart which had equivalent link between them and mBOM part.
However if the user iterates eBOM part but does not update equivalent link manually, I would still need to be able to traverse to previously linked upstream part
Need assistance with finding link to previous Non -Latest eBOM wtPart to fetch further associated documents from it
QueryResult upstreamResult = wt.fc.PersistenceHelper.manager.navigate(parentPart,
LOGGER.debug(">>>>> upstreamResult : " + upstreamResult.size());
while (upstreamResult.hasMoreElements()) {
Object partObj = (WTPart) upstreamResult.nextElement();
upstreamPart = (WTPart) partObj;
LOGGER.debug(">>>>> Upstream Part Iteration :" + upstreamPart.getIdentity()
+ upstreamPart.getIterationDisplayIdentifier());
boolean isLatestUpstreamPart = VersionControlHelper.isLatestIteration(upstreamPart);
LOGGER.debug(">>>>> Is Latest Upstream Part? : " + isLatestUpstreamPart);
if (isLatestUpstreamPart) {
flag = true;
LOGGER.debug(">>> Inside Is LatestUpstreamPart True : " + flag);
descByResult = PersistenceHelper.manager.navigate(upstreamPart,
EPMDescribeLink.DESCRIBED_BY_ROLE, epmDescribeCriteria, true);
IF NOT LATEST  -> Need to fetch previous linked object with Equivalence link
Thanks in advance!
Catalina
Community Manager
Hi @Rohaan
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
I'm not any help but I have been searching for info on how to Collect the Upstream wtPart when users are in the process of Revising a document with Described by links to wtParts.
The OOB behavior is to collect the latest wtpart and that is in the manufacturing downstream view. As far as I can tell, this is also in the Revise window.
