11-Garnet
Feb 20, 2017 9:27 AM UTC
How to get WTPartUsageLink attributes using InfoEngine* webjects?
I would like to get the WTPartUsageLink attributes like Quantity, Reference Designator, Unit etc, using InfoEngine webject.
I referred to this solution and used it to get the attributes - but the values returned are always null.
How should these attributes be retrieved using webjects?
Thanks in advance,
2-Explorer
Feb 20, 2017 10:24 PM UTC
Could you paste your I*E tasks?  Something like this should work
<ie:webject name="Query-Objects" type="OBJ">
   <ie:param name="instance" data="<%=instance%>"/>
   <ie:param name="type" data="wt.part.WTPart"/>
   <ie:param name="where" data="number='XXXXXX'"/>
   <ie:param name="group_out" data="part"/>
</ie:webject>
<ie:webject name="Query-Links" type="OBJ">
   <ie:param name="group_in" data="part"/>
   <ie:param name="auto_navigate" data="false"/>
   <ie:param name="output_type" data="OTHER_SIDE"/>
   <ie:param name="group_out" data="uses"/>
   <ie:param name="type" data="wt.part.WTPartUsageLink"/>
   <ie:param name="direction" data="uses"/>
</ie:webject>
<ie:webject name="Return-Groups" type="GRP">
   <ie:param name="uses" data="output"/>
</ie:webject>
smorla11-GarnetAuthor
11-Garnet
Feb 22, 2017 4:52 AM UTC
This gives me some of the attributes, but not all. Quantity, Unit etc are still not retrieved.
I saw another thread and found that changing the parameter "output_type" to "full" gives all the attributes.
Thank you for the help.
2-Explorer
Feb 22, 2017 2:29 PM UTC
That's correct. For querylink webjects, quantity and other link attributes will not be returned if you don't specify output type to full. the default is other_side which just returns the object it is linked to.
