May 23, 2023 6:24 AM UTC
How to listen to event while moving object from one container to another using move action?
May 27, 2023 8:14 PM UTC
I'm not sure but I would guess:
wt.inf.container.WTContainerMoveEvent
with  PRE_MOVE and POST_MOVE
18-Opal
May 27, 2023 12:00 PM UTC
Hi @KS_9713081 ,
Update the following properties in wt.properties file to generate events log/information when move action is performed.
wt.services.verbose=true
wt.services.verboseEvents=true
Jun 6, 2023 6:37 AM UTC
Hi....Thank you ..It works for me
Jul 18, 2024 5:31 PM UTC
I also need to configure WTContainerMoveEvent.POST_MOVE, can you share the code snippet, which interface to implement and method to call like notifyVetoableMultiObjectEvent. Thanks
