Aug 20, 2024 2:18 PM UTC
How to Programmatically set Release Target for Resulting Objects
Version: Windchill 12.0
Use Case: Requirement : Need to set Release Target Programmatically for Resulting Objects.
Description:
setTargetTrasition() is there but not getting a way to set Release Target.
  • Currently I have CN , CA and when I try to get change Record that time getting class cast exception for any object.
HelesicPetr
Aug 21, 2024 9:40 AM UTC
Hi @@_1647
you should use the persistence manager to store the change. You just change it in the memory of the java transaction and it is not stored.
// save the change on the existing record
PersistenceHelper.manager.save(recordToUpdate);
// save the new record
PersistenceHelper.manager.store(newRecord);
PS: if you write a code in the workflow, you have to define full class definition
wt.fc.PersistenceHelper
PetrH
Aug 21, 2024 8:39 AM UTC
Article - "How to obtain programatically a Release Target (Transition) of a Changeable in a Change Notice in Windchill PDMLink": https://www.ptc.com/en/support/article/CS184486
@_164713-AquamarineAuthor
Aug 21, 2024 9:02 AM UTC
Thank you Vladimir for article.
That is for to get value not to set.
To set Release Target using setTargetTrasition().
But after setting the Transition as " CHANGE "on Wc UI changes are not reflecting.
Is there any method to save or propagate the changes which madhe on Change Record.
HelesicPetr
Aug 21, 2024 9:01 AM UTC
Hi @@_1647
It is really good idea to share some snip code.
The class cast exception can be thrown because you expect some object type and use wrong retype object, but there is a different type. For example an Array.
PetrH
Aug 21, 2024 9:05 AM UTC
HelesicPetr
Aug 21, 2024 9:16 AM UTC
Hi @@_1647
Sorry that I repeat my self
It is really good idea to share your code.
PetrH
