How to reassign new lifecycle state
I have added 2 new states in Site >> Utilities >> Type and Attribute Management >> Customize Modeled Enumerations and after adding it to Site>>Utilities>> Lifecycle Template Adminitstration>> TKEPartLC, the new lifecycle is still not visible when I do reassign lifecycle for a given tkePart in windchill. It still shows the old lifecycle of TKEPartLC.
Fadel
23-Emerald II
Do you get any error/warning  in logs when reassigning LC
Buiꓘa
HelesicPetr
Hi @RS_13475894
How did you do it?
Have you really reassigned the LC correctly? do you see the lifecycle template change in the Lifecycle history on the object?
the number is a template iteration.
PetrH
joe_morton
Also check that you don't have another life cycle template with the same name at a lower level (Organization or Product/Library).
Catalina
Community Manager
Hi @RS_13475894
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Manager
