Aug 26, 2016 6:34 AM UTC
How to retrieve Quantity attribute for WTPart Structure?
I am trying to retrieve Quantity attribute for BOM Structure.
WTPartUsageLink puLink = WTPartUsageLink.newWTPartUsageLink(part, partMaster);
puLink.getQuantity().getAmount(); //gives quantity 1.0 always.
Aug 26, 2016 5:55 PM UTC
The code you are using isn't actually looking at persisted data. You're essentially creating a "new"  local WTPartUsageLink and I'm guessing 1.0 is the default value. If you would like to actually retreive the quantity from an existing link in the database, you need to get a reference to that link.
One of the APIs you could use would be:
WTPartHelper.service.getUsesWTParts(parents, configSpec);
JavaDoc:
getUsesWTParts
Persistable[][][] getUsesWTParts(WTList parts, ConfigSpec configSpec) throws WTException
Navigates from many used-by parts to their uses
part masters and applies a ConfigSpec to select the iterations
of the uses parts. Returns a three dimensional array of Persistable
where the first dimension is corresponds the the used-by parts passed
in. The second dimension corresponds to the part usage links from
the used-by part. The third dimension is two elements long where [0]
is the WTPartUsageLink and [2] is the uses WTPart or WTPartMaster
if the config spec did not select an iteration of the uses part. This
API does not support filtering.
Supported API: true
Parameters:
parts - Ordered list of used-by parts.
configSpec - The config spec to use to select the uses part iterations.
Returns:
Persistable[][][]
Throws:
WTException
Once you have the link you can use your code above to get the quanity:
You could also check out this article to show you how to get the link:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS49806
rkumar-101-VisitorAuthor
Aug 29, 2016 4:07 AM UTC
Hi Jamie
Thanks for your help. It worked for me.
Regards
Rakesh
