How to set a specific state through right mouse button action menu
I have a life cycle that contains out of the various state two that can be set with a Set State action. Both have a right mouse button in the Action menu. When I click either one, I get a pop up window (the same window for both) with a pull down from which I can select which Action/State I want.
Is there a way to have the pull down show the state that I select in the pull down based on which Action menu I click?
For example:
State 1 = Library. --> Action menu = "Library" --> pop up window pull down "Library"
State 2 = Publish. --> Action menu = "Publish" --> pop up window pull down "Publish"
The current behavior is that regardless of which action menu I select, I still have to make the secondary selection to pick the state I want in the pull down menu from the pop up window.
