How to test the code to check the type of WTObject
As per this thread - same question:
@CHASEONHO did you get this part figured out... I'm fairly new to all this... I have my eclipse environment configured (I beleive)  but have yet to figure out how to test code from it.
avillanueva
23-Emerald II
June 30, 2022
Are you asking how to setup Eclipse with Windchill or how to test checking the object type code portion?
My Eclipse environment is set up... I want to be able to run my code on an object and get system outs in the console so I can rapidly iterate the code with out having to plug it into my expression robot and create new PR objects to test.
HelesicPetr
Hi @ChiselnMallet1
You have several options how to run your code.
From Windchill shell call a java class (windchill wt.load.util.UpdateEditDTDUtility)
From WebBrowser to call  a java class with RemoteAccess (http://server.my.com/Windchill/servlet/WindchillAuthGW/com.ex.JavaPackange/MyMethod)
or create button in windchill to call a java class method
PS: very useful is a Customization Guide
PetrH
