How to use Info*Engine to get all the drw objects?
Hello, please tell me how to use Info*Engine to get all the drw objects?
I found a way to get the entire WTPart tree.
But I can't get the drw
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie" %>
<%@ page contentType="text/html;charset=utf-8" %>
<ie:webject name="Get-Properties" type="MGT">
 <ie:param name="ATTRIBUTE" data="wt.federation.ie.VMName"/>
 <ie:param name="GROUP_OUT" data="properties"/>
</ie:webject>
<html>
<head>
</head>
<body>
<ie:webject name="Search-Objects" type="OBJ">
 <ie:param name="instance" data="$(properties[0]wt.federation.ie.VMName[0])"/>
 <ie:param name="type" data="WCTYPE|wt.part.WTPart"/>
 <ie:param name="where" data="(number='НМЕА.305369.013-01')"/>
 <ie:param name="attribute" data="name,obid" delim=","/>
 <ie:param name="VERSION" data="LATEST"/>
 <ie:param name="ITERATION" data="LATEST"/>
 <ie:param name="group_out" data="anObjects"/>
</ie:webject>
<ie:webject name="Query-Tree" type="OBJ">
 <ie:param name="INSTANCE" data="$(properties[0]wt.federation.ie.VMName[0])"/>
 <ie:param name="TYPE" data="wt.part.WTPartUsageLink"/>
 <ie:param name="GROUP_IN" data="anObjects"/>
 <ie:param name="WHERE" data="number='*'"/>
 <ie:param name="DIRECTION" data="uses"/>
 <ie:param name="DEPTH" data="10"/> <!-- Уровень вложенности -->
 <ie:param name="ATTRIBUTE" data="number,name" delim=","/>
 <ie:param name="GROUP_OUT" data="output"/>
</ie:webject>
<ie:webject name="Display-Table" type="DSP">
 <ie:param name="BORDER" data="1"/>
 <ie:param name="GROUP_IN" data="output"/>
 <ie:param name="HEADER" data="Number,Name" delim=","/>
 <ie:param name="TITLE" data="Display-Table"/>
</ie:webject>
</body>
</html>
