How to use regular expression in queryspec search condition.
I have requirement to search object using queryspec which can have number with leading zero(to make it 8 digit length) or without leading zeros.
e.g. I am to search object number 66, query should be able to find object 66, 066, 0066 etc. I got regular expression to search( ^0*66$ ) need to know how to use in queryspec.
Fadel
23-Emerald II
Buiꓘa
Catalina
Community Manager
Hi @Gajendra
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Manager
Try this
// Constant expression using LIKE pattern to match leading zeros
ConstantExpression ce = new ConstantExpression("%66"); // matches 66, 066, 0066, etc.
ce.setUseEscape(true);
// Create search condition
SearchCondition sc1 = new SearchCondition(ca, SearchCondition.LIKE, ce);
Gajendra4-ParticipantAuthor
Thank you for the reply. %66 will also match to 166, 266 or any number with trailing 66? My requirement is get number 66 or with leading zeroes.
HelesicPetr
Hi @Gajendra
Generally, queryspec does not support regular expressions. You have to combinate the substitute sql characters as "_" for one character or "%" for multiple characters.
PetrH
