Jun 18, 2024 8:09 PM UTC
Howto get Engineering sequence of newly added customer parts
Version: Windchill 12.0
Use Case: fetching wrs data from navigate
Description:
In Master BOM in windchill, Customer have added new type of parts and its engineering sequence in new column. Iam getting those new parts in getPartStructure API. But i want the new column 'engineering sequence' data for new parts. How to fetch it using WRS API.
Community Moderator
Jun 24, 2024 10:38 PM UTC
Hi @AP_10343008,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
Jun 25, 2024 8:37 AM UTC
I got Engineering Sequence data from Part Usage links.
Thanks.
HelesicPetr
Jun 27, 2024 5:54 AM UTC
Hi @AP_10343008
And can you describe(share) the syntax what have you used? that it can be used as a Solution?
PetrH
