8-Gravel
January 17, 2024
I changed the server name but I don't know which parameter to change to adjust in windchill
Hello, I am unable to carry out the rehost process.
I need to change the server name so that Windchill doesn't lose communication. Would you help me ? I've seen the PTC documentation but it didn't help, it doesn't say which parameter I have to change so that the system understands the new server name.
The server name is spread out all over the application conf files, InfoEngine definitions, tomcat and Apache ...
only the tool can carry out such massive change consistently is the rehost tool.
so what is it exactly failing with the tool ? Can you share logs and config files of the rehost utility ?
8-Gravel
January 22, 2024
Hi, of course I will!
Could you give me your email so we can hold a call? This way I can show you more clearly
8-Gravel
January 22, 2024
