Mar 8, 2024 7:57 AM UTC
I need to retrive the Part from the BOM structure which are not having CAD Association.
"I need to retrieve the parts from the BOM structure that do not have a CAD association. Once identified, I want to associate an empty CAD assembly with each of these parts. The CAD association for each part should be named based on the respective part."
HelesicPetr
Mar 8, 2024 8:06 AM UTC
Hi @AR_9920456
If you need to find parts that do not have CAD from one BOM use the compare function "Compare to CAD Structure" from part detail page action menu.
Another way is to create a QureyBuilder report in the Windchill Report Management
The QueryBuilder report can be used in Advanced search and there you can interact with the result objects.
here is a report how to search EPM Document without WTP but you can change the direction...
CS390356 - How to create Query Builder Report to find "EPM Document" which is not associated with a "WTPart" in Windchill PDMLink
also you can use a one level report together
CS72503 - Report to get the bill of material (BOM) report for latest iteration of latest version in Windchill PDMLink
report technique
Windchill Reporting Resource
an Another way is to write own code to report what you need 😄
PetrH
Mar 8, 2024 8:52 AM UTC
any sample code to retrieve the parts which has not having CAD association
HelesicPetr
Mar 8, 2024 9:24 AM UTC
Hi @AR_9920456
If you want to write a code, then don't care about retrieving what does not have a association.
get the full BOM and go through the bom and check if the association exists.
code to get owner association is
QueryResult activeEMPDoc = PersistenceHelper.manager.navigate(sourceWTPart, EPMBuildRule.BUILD_SOURCE_ROLE, EPMBuildRule.class);
if the result is null or zero(empty) then the association does not exists
PetrH
